Search the forum,
Discuss No Luck with Electricians in Scotland in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Can I ask for some feedback and advice from the professionals on the points below?
Refurbishing two cottages into one, I had engaged an electrical firm to carry out the installation, but following very poor work and practice as recommended here I stopped the work and engaged another electrician.
Asking if he was qualified I was assured he was C&G qualified, and could sign off the installation at the end for building control.
I have to say his work was poor, he spent the first several weeks installing the floodlights outside. When adding an extra 10w flood some 12 inches around a corner from the last he ran a new cable back to the consumer unit, unclipped anywhere, and not in the cable tray for the rest of the run.
Installing conduit into the plaster to the sockets back boxes, the conduit is not earthed, not level and some drops have no fixings and as it is above the wall level the joiner will now have to cover with plaster board.
After many other errors, such as smoke detector cable left hanging with no longer access to the celling void, a smoke detector located so the door will hit it, PIR in wrong location, lights switch on the wrong side of the door etc etc
Reluctantly after pointing much of these errors out, he left site, sending a second invoice, yet he had given a written quote for the job to completion. On his last invoice he has charged for plugs and screws, drill hire, cutting discs, brackets, grommets, cable etc
The work done is not even half the work, yet he is charging more than 50% of the total quote.
It seems confusing in Scotland as with no part P, competent person, and limited availability of electricians, how can you trust and check installers?
The final worry is after investigation he has C&G Electrical Inspection and Testing (2391) does this make him qualified to do installations?
Those pics may not be pretty, but then you can't expect works of art from every spark. However, some of the other points you mention do smack of a lack of planning and care in execution. As for charging for drill hire, grommets etc if you had a firm quote, surely these "extras" are covered by the quote.
If I get a new tyre, or a puncture repair, I expect to be charged for the parts and labour, but not for the air...
Reply to No Luck with Electricians in Scotland in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello! I am looking into avenues into entering the trade, but I feel like all the information I can find online is incredibly convoluted and...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Awful time of a new installation by an idiot! He spent most of his time with his phone attached to his ear held between his shoulder and face...
5K
I commissioned an EICR to be done on a property that is in Wales as this is now a requirement in order to let on any new tenancies after 1st...
