- Reaction score
- 1,693
A 3 port valve switches boiler flow between hot water cylinder and radiators, a common method called "Y plan", and is the scheme in the circuit diagram you posted with the thermostat etc. The valve looks like the pic below, and is probably near your hot water cylinder, but might be elsewhere. The boiler flow output goes into the bottom port, the rads come off one side and the cylinder the other.Apologies for my ignorance, I'm not clear on the 3 port reference?
Or the other option is you have two "2 port" motorised valves, one for hot water and one for the radiator circuit (called 'S Plan').
I'm keen to know if a 3 port is actually what you have, because it's the orange wire out of this valve that is providing the power for your boiler! And these things are known to get stuck etc!
Just to say that's it's clear now that the reason you boiler is running all the time is nothing to do with the boiler itself, it's that the power to it coming out of that junction box is not switching off when it should, so I think there's something up indoors that is causing your issue.
