Search the forum,
Discuss operational limitation on EIC in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
newfutile
Supporter
after changing a consumer unit I have a high level flood light and photocell that can’t be reached.
on the EICR I can LIM these due to height .
the photocell is a NEMA plastic double insulated type
the floodlight however is a SON-T and I suspect its a metal case !
Reply to operational limitation on EIC in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
4K
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
I have an electric oven - now many years old. I have replaced the main circular 2.5kW oven element (ELEHY6708) several times over the years...
  • Locked
5K
