Search the forum,
Discuss Outside socket not working. in the DIY Electrical Advice area at ElectriciansForums.net
Hi, recently moved. We have an outside socket that doesn’t work, I checked the wire connections,. Just want to know if this looks correct, the live connected is the white wire, the 2 red connected to each other are also live.
I will get an electrician to replace the socket but wondered if the wiring is correct.
TL;DR
Should have said this is in Australia
I'm in the UK, and totally unfamiliar with antipodean wiring, but that looks like this may have been wired to a switch controlling it elsewhere. Is there a switch inside the house with an unknown function?
I'm in the UK, and totally unfamiliar with antipodean wiring, but that looks like there may have been wired to a switch controlling it elsewhere. Is there a switch inside the house with an unknown function?
Bingo!!! There is a switch indoors that we had no idea what it was for… only trouble is I have to get an electrician in to check it because when I switch it on it throws the power off.
obviously a fault on the outside circuitry. local spark fix in 20mins. i could do, but travel expense too much,
Reply to Outside socket not working. in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, I'm wondering if it's permitted to replace an outside wall light myself if I use the existing wiring from the old light. In theory I just...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
