Search the forum,
Discuss PCB In Line Fan Timer Question in the DIY Electrical Advice area at ElectriciansForums.net
Paul N
Dear All,
The back story is too boring to tell !!! Could someone please tell me if this PCB in the photograph has an adjustable time function ?
It was sitting in its own white back box on the wall close to the fan and was wired to a set of bathroom lights - it was supposed to operate the Manrose "In Line" fan for 5 minutes after the lights went off. The fan has never worked with it in situ, once removed the fan works fine. Presumably it was incompatible (?) or the fan needed more time to get going and clear the fog !!!.
Just wondered if there was an obvious adjust to the PCB to increase the time to test it for compatibility - the blue square perhaps ?
Many thanks in advance !!!!
Warm regards,
Paul
Reply to PCB In Line Fan Timer Question in the DIY Electrical Advice area at ElectriciansForums.net
Hi there, please help. I live in Florida and am replacing a ceiling fan in a bedroom. The new fan has no pull cords and no remote. It came...
I will be fitting an in line extractor fan in the loft to extract from a shower room. At present there is a ceiling mounted fan placed directly by...
  • Locked
Hi all! First up - I'm not an electrician, this is purely DIY. I have a little bit of electrical knowledge (degree in computer networking) but...
I have an electrical conundrum and would appreciate any input. I have an unattached garage that has an electrical line (underground) running to...
Last time I posted on forum it was on the thorny issue of over unity machines which alas got confused with perpetual motion -- and other supposed...
8K
