Currently reading:
Phantom Cooling Fan on Double Oven
Discuss Phantom Cooling Fan on Double Oven in the UK Electrical Forum area at ElectriciansForums.net
Seb
Hi all.
Has anyone encountered a double oven cooling fan being turned on by the use of an electric whisk on the same circuit?
Sounds bizarre I know but have just discovered the use of the whisk alone turns it on, without the oven even being used beforehand. Could some sort of high frequency signal be switching it on?
Let me know if you have any ideas. Cheers
EMI causing the micro/circuitry in the oven to switch the fan on probably. Lack of shielding or suppression in one or other of the two appliances. Daz
<Error - Sensible answer in line 1>
<Execution stopped>
Probably need to check if a diversity calculation was done before the cooker was installed. Thats what I was asked when I asked about cooker installations.
It might help if you down rated the plug to 13A no matter what the installation instructions say, like thats gonna help.
Qualifications, Pah!
Still spitting blood.
Reply to Phantom Cooling Fan on Double Oven in the UK Electrical Forum area at ElectriciansForums.net
