Discuss PVC Back Box w/ Multiple Knockouts in the Electrical Tools and Products area at ElectriciansForums.net
LewisM
Hi does anybody know of single / double PVC back boxes that have multiple 20mm knockouts like metal clad? Or are plain with no knockouts ?
The ones with one 20mm and trunking knockouts don't really work as when cutting the 20mm hole the trunking entry normally splits even when bracing it.
Marshall tufflex do them. Though I understand they are not A big seller in the UK so not cheap compared to metal. If you use a lot of them you can get them online more cheaply from any electrical wholesaler in ROI like CEF.
Try the following links for the Marshall Tufflex ones:
Part of an 1980's estate round here was built with conduit in concrete walls, stranded & sheathed PVC multicore cabling the conduit, and these style of mounting boxes - won some kind of design award at the time - but a nightmare for electrical alterations.
Reply to PVC Back Box w/ Multiple Knockouts in the Electrical Tools and Products area at ElectriciansForums.net
I know I’ve seen them before…. But I can’t think of a name. I’m needing a line of metal back boxes in a kitchen… 2 lots of 2x 2 gang and a 1...
Hello, Im really new to the world of conduit. I have some 25mm pvc conduit and cant for the life of me seem to fit back boxes with 25mm...
5K
Hi, I am wondering if any sparks out there know of a brand of 32mm deep PVC surface boxes with multiple knockouts for MT2 & MT3 ( 25mm x 16mm &...
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
Hi all, I am an experienced DIY electrician and I just wanted to ask a quick question about something since I am new to this forum, if it hasn’t...
