Search the forum,
Discuss Quad switch - one not working in the DIY Electrical Advice area at ElectriciansForums.net
It is difficult to say without some form of testing and inspection. Broken connection, broken wire, faulty switch, faulty lamp holder. If you feel competent isolate power and check connections at the switch initially then try the lamp holder if it is easy to dismantle.
It’s also possible that switches within that 4 gang are fed from different circuits.
Check a breaker hasn’t tripped.
Reply to Quad switch - one not working in the DIY Electrical Advice area at ElectriciansForums.net
Can I use multiple GU10 led lamps with their own PIR sensors in the same room? I have a row of existing lamps 600mm apart in a straight line & I...
Hello. Now that I've got you concerned/intrigued: I found this exact loudspeaker some time ago : ALS1000 D Soundstar -...
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
I've recently moved into rented property and I currently have no lighting in the bathroom (2 wall lamps and 3 ceiling lamps). The landlord...
Hello Forum! Yes I have an ice cream cart bike that is battery powered and yes I regret purchasing it! I have attached a generic picture of it...
