Search the forum,
Discuss Question about the Definition of #6 wiring standards for Thailand? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
WilliamC
Question about the Definition of #6 wiring standards for Thailand as of 2023?
I am having a House/Villa built in Thailand and I wanted to wire one room with both 110 & 220 capability? The contractor wrote back and said the cannot provide the 110 volt out let, but that they can wire it with #6 wire standard for Thailand. I'm not familiar enough with their terminology, and if I can successfully have them safely do this? Is there someone here who can explain the Pros vs Cons of trying to wire both 110 volt and 220 voltage to the same outlet? And what do they mean when they say that it will be wired with a #6 standard? They are also telling me that they do not have the 110 volt plug socket like we have in the USA. But if I provide it they will wire it using the #6 wire standard. So I guess my question is, if I provide the 110 volt socket outlet for them... is there an issue using the Thailand #6 wire code the mention in their email?
(Note: See email below.)
My name is Ms.Danita Arnopthananart
For the electric outlet on your request we will prepare the electric wire system with cable number 6 as your request it on the additional plan. But I apologize for the special socket you had request that we can not get it in Thailand. I recommend it to be on your cost and we will install it for you as it remarked on the quotation..
Reply to Question about the Definition of #6 wiring standards for Thailand? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi brains trust, I am aware of typical wiring and legalities hence the questions. Looking for a wiring diagram to allow me to use a dual switch...
I have an existing but unused 50A disconnect on the side of the house. It had been connected to an AC unit that got replaced. It has just 3...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
