Search the forum,
Discuss RCBOs for old Newlec board? in the UK Electrical Forum area at ElectriciansForums.net
lapsed
Is it possible to replace NLVB32 and NLVB10 MCBs with RCBOs, or is a whole new board required?
Board is labelled NLCU5PSW and is 20-25 years old.
It would be far far easier to replace the board than try and fit RCBO's, even if you can get hold of them. Its just the lack of space inside older boards that makes it a struggle, by the time you have stripped everything out to start again you are only left with a case held on with 4 screws so you might as well change that as well.
Plus the fact that you can sometimes get a whole new basic board from somewhere like Fusebox for the cost of a couple of RCBO's off different manufacturers makes it a no brainer.
Newlec was the own brand offering from Newy and Eyre (now absorbed into rexel) so they will be made by a manufacturer with newlec branding on them.
From the pic I'd hazard a guess that they are GE MCB's.
Reply to RCBOs for old Newlec board? in the UK Electrical Forum area at ElectriciansForums.net
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
4K
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
