- Reaction score
- 1,509
Kewtech Kewprove 3 and a Martindale VT12 for me. Modified the Kewprove so it'll stick to a metal enclosure, saving a bit of faffing
Discuss Recommendations for voltage tester with proving unit in the Electrical Tools and Products area at ElectriciansForums.net
Multimeters are frowned upon for this job for various reasons. One is they have a very high impedance (typically 10Mohm) so tend to read "phantom voltage" from capacitive coupling to other energised circuits, whereas the light/LED style take several milliamp so don't show this (in most cases).Good point. I have been using multimeters from long time but once here in UK I started to see those type of equipment. Very different.
The Testo 700 series have gone a long way to prevent most of that, being self ranging and will indicate "No Lead" if volts or amps are not selected correctly: Testo 0590 7603 760-3 Digital MultimeterBut more fundamentally it is the number of ways you can go wrong (using DC volts, or amps/ohms and blowing the meter fuse, having an arc-flash if unfused amps, etc) with possibly fatal results! Hence the idea that a voltage tester should be simple and unambiguous.
Looks a nice piece of kit. Which proving unit are you using for this multimeter?The Testo 700 series have gone a long way to prevent most of that, being self ranging and will indicate "No Lead" if volts or amps are not selected correctly: Testo 0590 7603 760-3 Digital Multimeter
Buying a basic multimeter can be a solution for a DYI Sunday's spark. However the options seems like to be those two:If I was buying a new basic multimeter I think I would go for the slightly cheaper Testo 760-2 as best value for money. But I already have access to at least 4 multimeters, a bench DMM, MFT, & Megger IR tester!
Still considering getting a silent voltage tester for the future, just now it is not used that often to justify another as it works perfectly (if annoyingly)
That is good to know.Not sure if I mentioned this before but, knowing that you detest noisy voltage testers, it's worth pointing out that all in the Fluke range can be silenced at the press of a button.
Reply to Recommendations for voltage tester with proving unit in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
