Search the forum,
Discuss Recommended brand for outside flood light in the Lighting Forum area at ElectriciansForums.net
Hi all, just wondering if anyone has a preferred brand of outside LED flood light (30watts with PIR sensor) Replaced a dud Screwfix brand jobby (LAP) like for like a couple of months back and the thing packed up before Christmas. I've been asked to source the replacement this time around and just curious to what people recommend.
I put a 10 quid amazon jobbie up at my house 6 years ago and it is still going strong , its a pir light so only comes on periodically so not left on for hours and hours, Think is Lepro
got a Ansell 30watt at home, been in 5 or 6 years. no problems. cost about £45.
Did they start to flash and then end up really dim?
When replacing them they where just pretty dim if I recall, had several others for other jobs that under wholesaler instruction I sent back as faulty, even though brand new and still in the box. Also took down working floods and replaced them when on same jobs.
I've had bother with pretty much all floods I've supplied be it Ledvance, Luxna, Elex, Luceco, Ansell. Have a house with about 20 Ledvance floods fitted and reckon only reason I've not been back to change any is they next to never turn them on (which begs the question, why are they even there!)
Reply to Recommended brand for outside flood light in the Lighting Forum area at ElectriciansForums.net
Hi all, I'm looking for a couple of PIR floodlights to replace old halogen ones, probably around the 50W mark would provide sufficient lighting...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
