Discuss Regarding cable specification in the Electrical Engineering Chat area at ElectriciansForums.net
A cable specification is like below.
-below-
LBR: Pull <=1KV(350-600)(SC)(Non-Armor)
What does LBR mean? and What does Pull mean?
And why in the US are AWG and kcmil mixed?
Under the condition of 350-600, which size cable should I buy?
You need to provide a lot more information about the cable and its application before anyone can answer that.
As to why the USA uses AWG (numbering based on what looks like a strange/arbitrary logarithmic basis) and kcmil (cross-sectional area in square inches subject to other strange choices) that is just historical practice. Or hysterical in some cases.
The rest of the world, including the UK that originated the "modern" imperial inch-based system back in Henry VIII's day (he imposed gov standards and enforced them, but the actual origins go back as far as Roman times), have moved on the SI (metric) units with cable size in square mm.
Reply to Regarding cable specification in the Electrical Engineering Chat area at ElectriciansForums.net
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
I’m in the process of changing my old downlights in the bathroom , I put them in years ago with advice from my late father who was a sparky, these...
It seems to be easy, these days, to buy fittings (often containing resin) that allow someone to tee into a pre-existing SWA cable. Some of these...
