Search the forum,
Discuss Regs and importance of following manufacturers instructions in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Marvo
Staff member
Mod
Mentor
Supporter
A recent thread on the suitability of a cable supplied preinstalled on a manufactured floodlight/pump had me wondering a few things.
Over the years the installation regs have placed more and more emphasis on following manufacturers instructions. I can see this would be fine for higher end manufacturers of commercial devices who go to great lengths to supply accurate manuals and guides for their products but given that the lower end of the market is notorious for providing a poorly translated single-sided photocopied flyer for their instructions....is it really a good idea to give this any legal weight?
I was also wondering how do you define 'manufacturer'? Many appliances are rebadged or even unbranded completely so the original manufacturer is actually unknown. I've even come across identical items from the same factory of origin under different brand names that come with completely different instructions and installer requirements. I've also come across identical items both of the same brand name sold by different 'authorised' agents who have their own varying installation requirements, would these be classed as MI's for regs purposes?
Suppliers often add their own restrictions on how/where a product may be installed/used in order to try to reduce the chances of failures under warranty. If the electrical supplier (think CEF or Edmunsons) you purchase the item from has their own installation instructions/requirements, or going even further down the chain maybe an Amazon vendor, would these carry any weight in the context of the electrical regs?
With regard to the suitability of the preinstalled cable surely this would be determined by the cable manufacturers data sheet which you would rarely if ever be able to confirm?
I just fitted some crappy customer supplied lights from Homebase… the instruction manual was a bit of paper with a QR code on it…
I didn’t use it. I mean, it’s only 3 wires, right?
This does present another issue, should you be keeping a hard copy of the MI's for future reference seeing as proving compliance of that job may depend on them?
Don't the UK regs say something a bit more vague like "taking the MI in to account" or similar?
I think it is an acknowledgement that MI may be missing, inaccurate, or simply plain stupid, so they never say they take precedence over the wiring regs, but that they might have something important to take in to account.
I'm going to get the wording wrong because I am far too lazy to look it up.
A previous version said 'must be followed' now says 'should be taken in to account'
Presumably for the reasons you outlined @Marvo
Reply to Regs and importance of following manufacturers instructions in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
In preparation for an EVSE installation, I am running the supply cable from the main CU, via catenary, to a new CU in my garage. The cable is 6mm...
On two occasions recently when changing light fittings I've been bored enough (after fitting the light naturally), to read the instructions that...
The never ending debate about supplies for cooking appliances. ??? I've just received an email from a customer that I'm in the process of quoting...
