Search the forum,
Discuss Removal of smoke alarm in bedroom in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys,
just before i call the sparks out, am i able to remove a smoke alarm and get it in a junction box in a bedroom? they are hardwired so it will be in a junction box then hidden in the ceiling.
they are two meters away from the other one which is in the hallway. its just the room is getting a refurb so best time to make a decision, the house came with a smoke alarm in each and every bedroom in the house.
If it were me, I would want to keep the smoke alarm in the bedroom, and not reduce the effectiveness of the installed system in detecting and alerting me to a potential fire in the house.
If you just find it a bit of an eyesore, you might be able to locate it somewhere less visually intrusive, but you'd need to follow the manufacturer's instructions on location.
The installers will probably have fitted it in the most convenient location for ease of cabling, whilst complying (hopefully) with the instructions, and won't likely have considered how it looks as you walk in to the room.
Reply to Removal of smoke alarm in bedroom in the UK Electrical Forum area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi, I'm completely rewiring a 9 bed 3 storey HMO in Jan, The fire detection required is just some linked lithium detectors in the...
Our Northern California home built on 1977 has a built-in Gard-Site Smoke Detector model 081-612. It does not has battery. Its mounted on the...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
