Search the forum,
Discuss Renovating a double decker help needed in the DIY Electrical Advice area at ElectriciansForums.net
Evening all, bit of a strange one I'm renovating a double decker bus and tonight went to check on the elections work and noticed there all bends in the cables and twisted for the lights and sockets am I right in thinking their shouldnt be as it can short and be dangerous I have rang him and he's said it's all fine and will be signed off just looking for some reassurance as this will be a 2nd home for me and my children any help appreciated
Interesting idea! Can you post some pictures of the wiring. And the bus!
Hey dpg this is some I will take some more as it was dark the cladding is what I've done today but now panicking as he's cable tied some of the wires to the railings and will always be exposed
[automerge]1574372406[/automerge]
These are just upstairs so far as working my way down
Looking interesting that. Yeah post some more pictures showing the twisted wiring you are concerned about.
Is the consumer unit in yet?
Yes the switch board has been done today and i will do be going down there after I've dropped the kids off at school
Reactions: DPG
Get some pictures posted and I'm sure people will give their opinions.
Hi Stacey is this bus going to be mobile or static as this makes a difference to the type of wiring that can be used.
Why do u say that? Is there something wrong with the electrics or the way I've done it as it will be driven to its final destination when I've finished and that's a few 100 miles
On mobile units you need to consider the vibration when moving. This generally means that you need to use a cable with fine flexible cores rather than solid cores.
I didn’t think it was going to be used as a mobile home. A lot of caravan sites have height restriction beams, and a double decker bus would be tricky to get in.
Is there a reason the internal walls are made from quite heavy and thick wood?
Static caravans for example are maybe only 1” square frame and thin plywood.
I'm assuming it's for the appearance that that type of wood has been used.
It's going on a site to be used for family when they come and visit also the wood is cls and thought it would allow more room for installation and cables as will be used all year round
Reactions: DPG
Evening all sorry for late photos here's the electrics that I have real concerns about
That round junction box is not suitable to be located where it cannot be accessed. And it would need fastening down anyhow as there is no cable support/strain relief.
But the rest is ok and suitable he's coming back Monday to finish off thank u so much for your help means alot
Am only looking at the photos on my phone and can't see much detail. The other people on here might have more comments.
Looking forward to seeing photos of the finished thing.
That install looks a bit poor IMO. The cables appear to be just strung from point to point without much thought or even clips. Looking at it they mightn’t even be in the safe zones.
Must admit I have no idea why the cables are not clipped that installation is the easiest to make a tidy job of and the white junction box should be totally unnecessary.
Afternoon all, sorry haven't updated recently it has come to a standstill as questioned the electrician and he walked off the job and have another electrician lined up for the new year so fingers crossed I can finish it off. Hope u all have a lovely Xmas thank you all for ur helpful comments and input x
Whoops.
Poor sensitive little guy.
Sounds like you’re well shot of him. A good spark will try to explain why things have been done in such a way, not strop off
(That autocorrected to “strip off”... so glad I noticed)
Sorry your project has come to a standstill
Reactions: DPG
Whoops.
Thank u and to be honest I would rather him strip off might of got my money's worth then ??? x
Reply to Renovating a double decker help needed in the DIY Electrical Advice area at ElectriciansForums.net
The symptoms its been having to start with was the fuel gage only working sometimes and when i play music from my phone when a loud song came on...
Hi all, Was wondering if anyone has come across this before and could maybe help - Its a new one to me! Customer recently altered layout of...
  • Locked
5K
HI all. I am not an electrician and know only but a few things about it so I want to ask a question . So Chargemaster is supposed to install a...
