Search the forum,
Discuss Retrofit of storage battery to existing Solar PV (worried about affect on FIT) in the Green Energy Forums | Green Energy Hub area at ElectriciansForums.net
I currently have a 3Kwh solar PV system which was installed over 12 years ago and getting a very good FIT payment and I don't want to lose it! I'm thinking about having a 10Kw battery installed, the idea being that I can divert excess generation to the battery and also have the facility to top up the battery from the grid (cheap-rate) during winter months.
I'm minded to go for the DC Coupled Solaredge 10Kw battery but my limited understanding tells me there are complications as far as the metering is concerned and topping up the battery from the grid i.e to account for any charging of the battery from the grid and avoid supply from the battery to the home being shown as generation. I currently have a separate generation meter only and submit readings for my FIT on a monthly basis.
My proposed installer said that he could fit a bi-directional meter which will measure consumed and exported electricity and net which will meet the rules as far as FIT is concerned. Is this actually the case?
I did briefly consider an AC-Coupled battery but it will be a lot more expensive. I currently have a Solaredge SE3000H inverter (this replaced a defective Sunny Boy inverter about 18 months ago). The proposed installer said AC coupled battery will require a replacement inverter or additional one fitted which will be more expensive.
If it helps, I have a smart meter and on the Octopus Go tariff. I have a PHEV which I connect to a Zappi for charging. Diverting excess generation to the car is problematic as the Zappi will only charge the car from solar when there is an excess of 1.4kWp which doesn't happen that often.
Another related question, solar pv will charge the battery but how is this measured? For example, if I generate 20kWp and 10Kwp is taken by the battery, will my generation figure be 20 or 10kWp for FIT puposes?
Welcome you thoughts/advice please
Reply to Retrofit of storage battery to existing Solar PV (worried about affect on FIT) in the Green Energy Forums | Green Energy Hub area at ElectriciansForums.net
I am a Napit registered electrician and want to get into Solar PV and battery storage. I have boot camp booked in April but am not hearing good...
Hi I currently on a job where the garage is having an office built above it with solar panels installed on the roof. I have ran a 16mm 3 core...
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
Hi folks, I have recently had a 5kW Solis inverter and 15kW/hr of batteries installed. Everything is working fine, but I have some concerns about...
We have a 5.5kW incoming supply, which cannot practicably be upgraded due to our remote location in the mountains. Can I use a PV array and...
