Discuss Right side socket of Double wall socket switch won't switch off. in the UK Electrical Forum area at ElectriciansForums.net
Double wall socket switch won't switch off. It just flips back to on. The left side one is fine. It used to do this 3 years ago then was working again. Now it's back. Do I have to replace the entire socket unit? Is that easy to do and legal on your own? Thank you
Yes, the entire socket front needs replacing.
it is a fairly straightforward task for someone with some experience of DIY electrical work.
if it is a rental property, just let the landlord know.
if it is your own, then it is probably worth getting a local spark to do it.
if there are other obvious safety issues then at least they will point them out to you.
Reply to Right side socket of Double wall socket switch won't switch off. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
