Search for tools and product advice,
Discuss Ring Doorbell - Is it possible to get power from light switch? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
So I'm wonderingIMG_1930.jpg is there's a way to grab some low voltage power from the back of a light switch/ I have no other way of getting power to my Ring Door bell and I would like to not have to use batteries.
depends if theres a neutral in the switch or not.... Older houses didnt, newer ones maybe.
you would also need something to contain the transformer than reduces 230V down to 12 or whatever it needs.
Reply to Ring Doorbell - Is it possible to get power from light switch? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
Hi, So I ended up with a Ring video wired doorbell instead of a Byron video wired doorbell as B&Q were out of stock (had ordered online) and they...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hi, A lot about this fault confused me to be honest. So customer complained the doorbell was not working as intended. By that I mean the chime...
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
