Search the forum,
Discuss Running wire around ductwork in the DIY Electrical Advice area at ElectriciansForums.net
Hello all,
I'm renovating my kitchen and had a question about running wire around ductwork.
In attached pictures - I need to have a receptacle and a dedicated dishwasher line to the right of the ductwork. However, there is no good way to avoid the ductwork without running about 40 feet of additional wire to go up, around and back down to the basement.
I already ran the dishwasher line. See picture. This didn't seem like it would be up to code. I don't want wire touching the ductwork. I can go over or under the ductwork, but either way there is not much room.
Someone mentioned putting some pink insulation in between the wire and duct, but it still seems like it would be too close to the drywall once I do the basement ceiling. Should I staple it anywhere near the ductwork?
Thanks,
Nick
Reply to Running wire around ductwork in the DIY Electrical Advice area at ElectriciansForums.net
DIYer here. I'd like to install an electric car wall charger myself. It calls for 6/2 romex which I have. Unfortunately my panel is in my...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
Hi there. I am a doing some DIY kitchen work. In Ontario Canada, code allows either a split 15 amp multi-wire circuit or a 20 amp circuit (each...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
