Discuss Schedule of Test Results: editable PDF based on IET Model form in the Electrician Resources and Downloads area at ElectriciansForums.net
happysteve
Supporter
happysteve submitted a new resource:
Schedule of Test Results: editable PDF based on IET Model form - Looks just like the IET model form... but you can edit, save and print it in any PDF viewer.
This is a standalone Generic Schedule of Test Results, that goes either with an EIC or an EICR, in the format of a PDF. You can fill out the details using any PDF reader. It is derived from, and pretty much identical to, the IET model forms, at: http://electrical.------.org/wiring-regulations/forms/2015-amd3-forms.cfm?type=pdf The only thing I have added is a "Ref" field in the top right of the page, for you to add a reference (e.g. invoice number and page). There is a copyright...
Read more about this resource...
Yeah, this one page form alone is many (many) hours of work, manually making every field in the form have a unique name. I've tried it on a few different PDF readers. There are issues when merging PDFs if the forms are still "active" (ie you can still edit the values), but once you sign and export (so it's no longer editable) it should be safe to merge with either the EIC or EICR, or other test sheets. :)
hiya sorry to be a pain but can't input the full bs no for the protection device
On the test sheet (column 3)?
I can't see an issue from my end. The fields take 6 or 7 characters, depending on the width of the characters - so something like "60947-2" is still legible (just the right hand edge of the "2" missing).
You could always shorten the BS(EN) no, and put a note either in the remarks column, or in the box at the bottom of the form.
Reply to Schedule of Test Results: editable PDF based on IET Model form in the Electrician Resources and Downloads area at ElectriciansForums.net
happysteve submitted a new resource: Circuit details + test results - extra sheets for EIC/EICR - BS7671 2018 + A2:2022 - Fillable circuit...
happysteve submitted a new resource: EIC - Electrical Installation Certificate - BS7671 2018 + A2:2022 - Fillable EIC PDF form for 18th Edition...
Eh up :) I've done some new PDF forms for BS7671 18th Edition Amendment 2 2022 (the Big Brown Book), based on the IET model forms. You can fill...
12K
happysteve submitted a new resource: EICR - Electrical Installation Condition Report - BS7671 2018 + A2:2022 - Fillable EICR PDF form for 18th...
happysteve submitted a new resource: MEIWC - Minor Electrical Installation Works Certificate - BS7671 2018 + A2:2022 - Fillable MEIWC PDF form...
