Discuss Self Cancelling Turn Signal "Noise" (Motorcycle) in the Auto Electrician Forum area at ElectriciansForums.net
Please bear with me as I lay this out..
What are we dealing with?
- Motorcycle
+ I recently installed a plug-n-play self cancelling turn signal module. There is a power supply, ground, and the rest plugs into the existing wiring harness.
Operation of self cancelling module
- The module can be programed by rapidly pulling the brake lever 5 times to enter the program mode.
- The turn signal indicator flashes to acknowledge when it goes into program mode.
Issue
- While at higher speeds the indicator randomly flashes, and will go into program mode itself.
- If other electronics are used (like the horn) the indicator flashes.
Question
- Is there a way to isolate the self cancelling turn signal module?
+ If so, please advise on components, re-wire suggestions, etc
Thank you in advance!
I think it may be a vibration issue. s
Vibration and maybe air pressure.
(though following my son on his 125 he was always activating the brake pedal with his feet a little ! )
If multiples switches on same circuit -Could try measuring volts across switch as hit other brakes !
If brake is not required in normal operation of clever uniit --
break the link between brakes and the module as @plugsandsparks arks suggests.
Reply to Self Cancelling Turn Signal "Noise" (Motorcycle) in the Auto Electrician Forum area at ElectriciansForums.net
E
If you want to save on your monthly electric bill and reduce your greenhouse gas emissions at the same time, you might buy a new, energy-efficient...
Electricity News --
E
