Search the forum,
Discuss Shed wiring- earthing in the Australia area at ElectriciansForums.net
I've wired some cable to a small 3x3 shed with 2 gpos, a 15a GPO, and a light. The shed is about 2m away from the house on a concrete slab.
The 15a gpo (4mm) is run back to the house mbox location currently coiled above in the roofspace.
The light (1mm) and gpos (2.5mm) are run to the house and left by the nearest junctions ready for connecting.
Everything is wired completely enclosed in conduit and sealed mounting blocks so there's no bare cabling exposed anywhere.
My concern is earthing. The shed is basically a colorbond shed from Stratco and needs earthing from what I read from AS3000. I need this step properly sorted before I liven it up.
Do I run an earth wire (like a 6mm) back to the mbox to be bonded to the main earth?
Reply to Shed wiring- earthing in the Australia area at ElectriciansForums.net
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
Hello, I am an enthusiast amateur undertaking wiring of two outbuilding under a building notice. I am soon to be subject to a first fix inspection...
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
