Discuss Shut AC supply down to dolar via NO fire alarm IOU in the UK Electrical Forum area at ElectriciansForums.net
Hello People
Our Enphase solar system needs to have the AC supply shut down via the fire alarm contactors local input output unit that has NO & NC volt free contacts.
Is there a kit i can buy or should i just buy a DB with a 4 pole contactor etc? how would you do this
Bevause its an enpahse solar system Just think of it as a regular AC load that needs controlling as there is no DC strings ETC as its just a load of micro inverters connected to a single AC supply cable behind each panel
Reply to Shut AC supply down to dolar via NO fire alarm IOU in the UK Electrical Forum area at ElectriciansForums.net
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
Hello, I am fitting a Telecom 8 Compact burglar alarm system to a boat. The boat has both nominal 12v DC supply (ie up to 14.2 v when engine...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
