Search the forum,
Discuss single phase motor reversing itself in the Commercial Electrical Advice area at ElectriciansForums.net
evening all
ive got a single phase AC fan motor running normally however occasionally on start up it starts in reverse. i have 4 no fans, and this is happening to 2 occasionally. now these are in a fresh air chambers and i was starting to think that the airs blowing over the fans causing reverse rotation and then the capacitors havent got the umph to overcome this so they speed up backwards. is this possible?
all the fans are supplied via individual single phase inverters, all parameters are the same? ive never seen anything like it before
is there anything else that could cause this?
Cheers
What power rating are the motors? Do they run at or near normal full speed or are they deliberately being run slowly?
It is possible that the capacitors are failing; how old are they?
evening all
Cheers
Hi
The first idea is that there might be a conflict in the connections of the fans. However, since the issue been seen in a fresh air chambers it's possible that the reverse rotation may occur during blown air form the atmosphere.
Maybe there is a clutch that avoiding fans from rotating reversely .. if so i would suggest installing any means of devices to force the fans to rotate in one direction as long as these fans are only to blow air in one direction.
Neglecting that the fan's drivers aren't strong enough to overcome the external climate conditions, a mechanical means might be a good solution.
Reply to single phase motor reversing itself in the Commercial Electrical Advice area at ElectriciansForums.net
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Hi Forum Members I have a 4 pole single phase 240VAC 315 watt motor from a central heating heating system that I think is bad. It's the room fan...
I posted a month ago regarding a single phase motor + panel I have been given to try and sort following water damage to the panel. The assembly...
Hi I have a 3 phase 400v motor wired in star configuration it is controlled via a 3 pole 415v coil contactor which is switched simply via a stay...
Hi guys, Been given a motor and associated control gear within a panel that has been water damaged. This motor has 3 windings U1/U2, V1/V2 and...
