Search the forum,
Discuss Sky + & TV first Fix in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi all,
Looking for some advice on first fix for sky and freesat TV,
I've quoted a WF100 shotgun and a single to both bedrooms and lounge, plan was to run all shotguns to external point for Sky to terminate into LNB and fit amp and digital aerial for the 3 freesat points. Terminated in each room with a Dual SAT/TV/FM euro plate (RJ45 alongside)
However if they don't want to pay for multiroom and want to use the RF2 and magic eye set up is there enough cables or should i run an additional single from the lounge? presumably it goes back up to a splitter then down to the other 2 Tv's via on of the shotgun cables?
Reply to Sky + & TV first Fix in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi All, Electrician, not TV/Sat Engineer. Currently in process of first fixing new build and client has asked us to install cables (first fix)...
Hi, Looking for some advice on the best way to do this. We are looking to add quad plates and LAN to rooms throughout the house. Most rooms will...
Hi. I moved into a property last year and have sky here using their existing dish and wiring. I noticed a few months back that I was only...
  • Locked
I have had a bunch of camera, I'm trying to find a camera I can leave and it alerts me when it's found somebody. I don't want DVRs and cables...
I'm just finishing a part rewire on a friends house that's been extended. He extended the kitchen into a new lean to style conservatory. In the...
6K
