Discuss SMA Sunny Boy Earth fault / Water penetration in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
V
VMan
Afternoon all,
Just thought i would share my afternoon with you all.
so i have 2 x SMA Sunnyboy 1200 inveters both situated outside next to each other(IP rated of course), when i noticed an earth fault today.
Following the manual, i tested the string, + to PE and - to PE, both 0 Volts
So went onto page 59 - testing the varisitor inside.
When I started to loosen the lid of the inverter, a shed load of water came out of the inverter!!
The inverter has never been opened before since receiving it from the wholesaler!!
Ended up drying the inside of the inverter and there you have it, earth fault fixed!
Just a heads up for you all.
V.:banghead:
It's normal for a Sunny Boy 1200 to be opened up somewhere between leaving the factory and being commissioned in order to set the language to English on the DIP switches. Sounds like whoever did it didn't put the lid back properly.
Reply to SMA Sunny Boy Earth fault / Water penetration in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
The other night, neighbour knocked my door. She said she'd gone to use their outdoor tap, and she thought she'd got a shock. Went and had a look...
Good afternoon all, today I experienced a near death electric shock. This happened on a single phase domestic property! I was carrying out a few...
Hi guys, I am new to the forum so be nice! I used to install solar PV systems back when the tariffs were still good, and I've never had to go...
5K
Hi you beautiful people. Just been looking at a rather confusing and disgusting job in a two floor ex-council house and wondering if anyone could...
6K
Evening all. Just wondered what everyone's sequence was for inspecting/testing main bonding when carrying out EICRs? I was at property recently...
4K
GEOFF S
G
