Search the forum,
Discuss Smart switch for light fixture that uses 12v ac transformer in the Lighting Forum area at ElectriciansForums.net
supgroup
I have installed a number of 120v smart light switches and smart bulbs which I have set up on a schedule via an app. I would like to add another smart light switch for a light fixture that has a 120v to 12v transformer inside the light fixture, lighting six 12v (previously halogen) currently LED bulbs. I would like to add a smart switch to this fixture so I can add that fixture to the schedule. I'm wondering whether the 12v transformer will work properly with a standard (non-dimming) Smart Switch.
Any feed back would be greatly appreciated!
Thanks,
Sup
For information's sake, I was able to successfully install a smart light switch for this fixture using a 120v to 12 v transformer. I had assumed that it would shut the power to the transformer the same as any other electrical fixture, but I just wanted to make sure that I wouldn't destroy the transformer. It does work the same without any issues.
Reply to Smart switch for light fixture that uses 12v ac transformer in the Lighting Forum area at ElectriciansForums.net
I have an inground pool with a 22 year old, 120vac light fixture in a niche connected to water-holding conduit running to a switch in an...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Ceiling closet light blew out. Checked bulb. Bulb good. Have 120v leaving light switch. Removed fixture. Have 120v at wires in ceiling when switch...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hi all, We have a monorail in the kitchen with 6 lights, currently 24v halogens (MR16 GU5.3). The transformer is tech lighting AT6024T. I want...
