Currently reading:
so ive just done the plumbing side of a shower...
Discuss so ive just done the plumbing side of a shower... in the UK Electrical Forum area at ElectriciansForums.net
E
elsparko
is it possible for a mixer tap to be plumbed incorrectly? i turned it to "cold" and it "emptied the system" after closing what i assumed to be the stop cock into the property
popped the shower valve off and i get hit with mains pressure water :coldsweat: now i REALLY have to find the stop cock lol
luckily i managed to contain the jet inside the shower screen and tray, but even that began overflowing, did eventually find the stopcock buried at the back of a cupboard under about a decade worth of hoarding
glad the tenant wasnt home, managed to get the floor dried up and you would never know how close to disaster they came, all they will see is their new working shower and think "ooooh what a professional job"
Fixed.......
No. I definitely meant a plumber.
I have no problems with elsparko's electrical experience, whatever his profile picture may suggest. Its his H2O management I was referring to.
I've done few shower swaps and not had much issues. Mostly come off the cold feed at the bath. That's a good one to check.
Good ones come with a ball valve on the pipe. Nice and easy.
One was top floor on a block of flats. Stop cock under kitchen sink turned off everything except the shower. Had a crawl through the attic and found the main service water main. There was an isolating valve for each flat there, and a T off the main for the shower just after the isolator.
Lol a 6 year old Range Rover at £8k is £8k for a reason as they are money pits when they go wrong they go wrong big time, the turbo version is worse as its a body off job to replace the turbo.
Reply to so ive just done the plumbing side of a shower... in the UK Electrical Forum area at ElectriciansForums.net
