Search the forum,
Discuss soft starter for 3 phase motor in the DIY Electrical Advice area at ElectriciansForums.net
Sajith
Hi All,
I have recently purchased a motor soft starter from aliexpress for a 3 phase motor
Before connecting load I measured the input and output voltages.
Input voltages between each phase is 400V. However when I measure the output, voltages (after timer delay) is different.
Output voltages are as follows
Phase1-Phase2 = 450V
Phase2-Phase3 = 300V
Phase1-Phase3 = 270V
Is this normal behavior for a soft starter or the is the unit defective. I did not connect the motor because of this, could this damage the motor ?
Thanks in advance
Sajith
Reply to soft starter for 3 phase motor in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
I want to check the insulation of the 3-phase 400VAC asynchronous squirrel cage motor. Motor's stator windings are connected in delta. I've read...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
