Discuss Solar Iboost diverting electricity to the hot water tank in the Solar Thermal Advice Forum area at ElectriciansForums.net
pob1976
Hi, I have a Solar Iboost and I understand that when I export electricity, it gets directed to the hot water tank. Is it supposed to be directly heated by solar, or does the mains add to it along with the solar? My smart meter is showing that I am using 2kw when the Solar Iboost is diverting electricity to the tank. The screen on the Iboost says heating by solar, but that is not the case if its drawing 2kw as well.
Reply to Solar Iboost diverting electricity to the hot water tank in the Solar Thermal Advice Forum area at ElectriciansForums.net
Hi, I have a 6kw PV with a 6kw Growatt battery and invertor. I have a solar iboost going to the hotwater tank. Recently I had a Ohme Home Pro...
Is it possible for all or at least most electricians to be trained up in the wiring of solar PV installations, particularly the iBoost or Eddy or...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Hi, I've got both a solar pv and an ashp system. The solar system also has 2 batteries and it's configured to fill the batteries first and then...
I have a 4.8kw solar diverter with 2 x 4.8kw hot water systems. Is there a switch that will only heat one hot water system at a time and switch...
