Looks like the solis is in control here, assume that the display is from the solis. What is the model no of the solis?
Discuss Solar inverter problem? in the UK Electrical Forum area at ElectriciansForums.net
Ok thank you. There is a plate but my phone won't let me take a pic as the cupboard is too dark. I'll try tomorrow and get some light on it. Thank youThere should be a data plate, probably on the side of the invertor casing, just take a pic
Got it off hereJust found this on the Solid site, does this sound correct?
F6---4kW single phase Energy Storage Inverter。
Thank you I understand. going to grab a torch to try and take a photo of the panel. I understood as you say, that the battery would kick in once solar produced is less than what is used, but as the usage rises when the solar rises and usage goes to zero when solar is not produced the battery never kicks in. ? Off to tryYes but the devil is in the detail, so you need to know exactly what Solis product you have. Basically, the output of the solar needs confirming with a clamp meter and the load of the house ditto, against what the display is showing, only then will you know what is wrong. I cannot help until i know what product you have and access to the installation manual for CT locations against what has been installed and what settings have been put in the commissioning parameters of the invertor.
What you should see is:
1. PV output A/C correctly measured
2. House load correctly measured
3. If PV is greater than house, battery charges
4. If PV is less than house battery discharges until exhausted (like at night)
cheers
P&S
Is this enough for your needs?Thank you I understand. going to grab a torch to try and take a photo of the panel. I understood as you say, that the battery would kick in once solar produced is less than what is used, but as the usage rises when the solar rises and usage goes to zero when solar is not produced the battery never kicks in. ? Off to try
Reply to Solar inverter problem? in the UK Electrical Forum area at ElectriciansForums.net
