Discuss Spa bath with lights in the DIY Electrical Advice area at ElectriciansForums.net
kilpats1
I have a spa bath, with lights, pump and lights are straight plugged into mains with 2C+E for pump, there is an additional ground wire on metal body of pump. Question I have is this ground cable required as pump is installed on plastic feet and onto block wood with no access to the pump. There is an earth point I can get electrician to connect it to but as far as im aware all im doing is creating another potential path for current if pump already has mains earth
If possible, contact the Spa maker for advice.
If the connection exists, it is required by code that it be correctly wired. It is also definitely safety-related, so don't ignore it.
My guess is that the extra earth connection is there in case something goes wrong with the pump. You do not want the pump to apply any power to the water or to someone touching the body of the pump, whether due to a short in the pump or just leakage.
Reply to Spa bath with lights in the DIY Electrical Advice area at ElectriciansForums.net
I’m running a feeder from main panel into spa panel that I’ll mount on exterior wall of house , will run through basement ceiling. Im thinking to...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Hi Can anyone clear up or explain in a bit more detail what could potentially be causing the results I have. I have just tested a 32a ring main...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
