Discuss SSE DNO 4kw Solar Panels with battery storage, zero export in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi,are you at present,tied to a contract/tariff,for your existing panels?
If you're claiming FiT for the original installation, are you planning to run the new panels thru the same generation meter? If so, you need to tell your FiT provider. The new panels won't be eligible for FiTs so the output will be divided up pro-rata.
The original inverter is probably sized for a 2kW system. You could upgrade to a 16A capped hybrid inverter and add another 3kW (not 2 kW) of panels (roofspace permitting).
If you plan to keep things separate, to keep within G83 (G98) regs, you'd better stick to a 1.5 kW inverter (whilst retaining the original inverter).
........I think the question of whether it is allowed or not is answered as I spoke to my DNO just now and I have explained what I want to do. They have confirmed that if I keep the PV panels total under 3.68kw, it can be approved under Fast Track G83.....
Reply to SSE DNO 4kw Solar Panels with battery storage, zero export in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
