Discuss Steel conduit in tight spaces in the UK Electrical Forum area at ElectriciansForums.net
I need to run a length of steel conduit. One end it will connect into a standard 25mm BESA box, on the other end, it will go into a sharp elbow. The conduit has to thread through a hole in the floor that is very close to the wall. If I thread the conduit through the hole and then place either the BESA box or the elbow on, it stops me from being able to turn the remainder 360 to screw in the other end.
Is there a trick I don't know about when in situations like this?
Use a running coupler (Google will help) to complicated to explain for me, not any good at drawing etc, try Google or You tube, sure you will find something to show you how it's done, good luck.
Reply to Steel conduit in tight spaces in the UK Electrical Forum area at ElectriciansForums.net
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
I have an older Crouse Hinds board with a 200A service. Due to recent rehab on the house, I found I have the need to install a sub panel. I...
I'm about to replace the cable from a starter to an existing 2hp 3-phase 3-wire motor adjacent. The motor is rigidly bolted to a bed and has a...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
