Discuss Sub panel breaker amperage upgrade in the UK Electrical Forum area at ElectriciansForums.net
Deonvas
I need to install a charger for an electric car, which needs 60 amp breaker. My main panel has a 200amp breaker and services 2 sub panels, both via 60 amp breakers. My issue is that there is no space in the main panel for a 60A 240V breaker. I do have space in one sub panel (basement) which is ideally situated to service the charger in the garage. The cable to this sub panel is ‘AL type se style r type xhhw 600 3 cdrs 2 awg’. Would I be able to change the breaker serving this sub panel from 60 to 90 amps in the main panel, then add a 60A breaker in the subpanel for the charger?
Pictures would be nice but do not change that breaker to a 90 amp. You can buy slim line breakers and free up space. Just because you have to install a 60 amp service, don’t mean that it’s going to pull 60 amps. At best it will pull maybe 25- 35 amps maximum
Reply to Sub panel breaker amperage upgrade in the UK Electrical Forum area at ElectriciansForums.net
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Hello, I am a homeowner and have a solar project coming up. I intend to install a 9kw solar system but I am not sure if I have to upgrade my main...
New member and DIY. I have a 60 AMP breaker going to a sub panel for a workshop. Two months ago I bought an electric car and a 40 AMP charger...
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
