Search the forum,
Discuss Super Rod Mega set. Get one now!! in the Electrical Tools and Products area at ElectriciansForums.net
NDG Elecs
Now I have read numerous peeps on here saying they are worth the money, but I doubted it and refused to get a set. I put up with my cheap rods, some accessories and plenty of insulation tape.
Having two nearly full rewires to do I thought stuff it and decided to get a set.
They are brilliant. Excellent quality and they cover nearly every possiblity. I was aware of cable socks and seen them being used but had never used them before myself, and can only say they are such a time saver. And the magnet and chain are good too. My favourite is the really bendy 1m rod though, guess I am really easily pleased!
If anyone reading this has pondered whether to get a set I would say get online and order one NOW, you really really really will not regret it!
The only little niggle I have with the set is that they are around 3-4mm wider than the cheap set I have, which
PS I don't have shares or any other interest in this company!!
Can you compleat the end of the sentence.
OK Anthony, I will just for you mate! Think I was going to say which........means you need to have bigger access holes if pulling a few cables through. And that sometimes space can be tight. The thinner diameter of the cheaper rods is defo the only possible advantage they have over the Mega Set.
Reply to Super Rod Mega set. Get one now!! in the Electrical Tools and Products area at ElectriciansForums.net
Electrical2Go - Save Time Installing Cables with Super Rod At Electrical2Go, we're constantly striving to bring you the latest and most...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
