Discuss Tail light wiring help needed please - Panigale 1199 S in the Auto Electrician Forum area at ElectriciansForums.net
Hello all,
I have a tail light for a '12 Ducati Panigale 1199 S, that I can't get working properly. The brake light / daytime running lights work fine through the factory connector. The turn signals are the problem, they do not work independently - they flash like hazard lights.
The tail light only has the 'hot' wire for each blinker (no ground) and comes with a resistor to be installed as well. I've added a summary below of the wires shown in the attached picture. Any help would be greatly appreciated.
  • Red arrows indicate the turn signal wires from the new tail light (hot only)
    Green arrows indicate factory turn signal wires (hot / ground)
    [*]Black arrow indicates the resistor that should be wired in as well.
Thank you kindly
Hi
Did you fix your lights? Would love to see a photo of your bike!
Reply to Tail light wiring help needed please - Panigale 1199 S in the Auto Electrician Forum area at ElectriciansForums.net
Greetings. I'm having problems with the hazard lights in my 1999 chevy Blazer. It works as expected for some time with both sides blinking and...
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
Hi All, I am looking to install a Quinetic double gang in line receiver switch (QURS2W) in my hallway on the ground floor to control the lights...
