Currently reading:
Taped up joint
Discuss Taped up joint in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the add
Trying to keep this short customer had a leak in her bathroom which required the downstairs ceiling to be pulled down and replaced.
In doing so this junction was found, the house was re-wired 5 years ago
and certificated! the problem I have is I need to reposition some of the lights in the ceiling it will probably test up ok, just want to know how I stand do you leave it or try and make it good ? the electrician has stated that this is perfectly acceptable
That is totally unacceptable. Conductors and terminations must be correctly contained, that would not include unenclosed block connectors. Wrapping it with insulation tape makes absolutely no difference. I would question the competence of anyone claiming to be an electrician who says that is acceptable.
It is worrying what else is hidden like that.
Thanks for the add
"The Electrician" and I use the title with tongue in cheek is talking out of his or her backside, needs sorting properly, as it stands it's diabolical. who ever did this wants seeing too.
As previously stated if they feel that is acceptable then their competence is in question. If they are not willing to rectify the situation and to be honest I wouldn't want them to you have made the first steps in lodging a complaint to their scheme provider, that being you approach them first for a solution.
Assuming they are in a Scheme Westward 10.
I will post the outcome
But looks like the old story of electrician doing install and one of his mates signed it off
But still bemused they are going to turn up and try and justify it
Just to add they left a bare live end coming out of one of the downlights see how they get out of that!
They’ll do what they always do mate......”wasnt like that when I left!”........I’d be doubtful if the person signing it off even saw it, misplaced trust in his “mate”....and the person installing obviously couldn’t care less cos he ain’t putting his name to paper......sounds like a right pair of clowns ??
Those WAGO boxes are such a faff, aren’t they..
Like @Baddegg says, they’ll try to weasel out... “the box has been taken off” and point the finger at you.
Stand your ground, and make sure all your work is up to scratch, or they’ll find something to discredit you.
if they ever actually turn up
That really does look a brown ball of mess.
Could at least of used Sellotape! :tearsofjoy:
the proper way would have been Grey gaffer tape :kissingsmiling:
[automerge]1592151867[/automerge]
I actually went to a job today where an old outside floodlight was faulty and tripping the house rcd When it rained.
so I took the light down (customer hasn’t purchased a new one yet) so I fitted a black wiska box on the wall over the cable and quickly put cables in wagos.
the old chap watched me the entire time and was well impressed i went to the trouble of screwing a box to the house For the cables.
he said ‘ I thought you would just cut the cable and rap It up in tape’
Reply to Taped up joint in the UK Electrical Forum area at ElectriciansForums.net
