Currently reading:
Texecom Premier24 sharing a BT phone line with a Tunstall ‘Lifeline’ alarm.
Discuss Texecom Premier24 sharing a BT phone line with a Tunstall ‘Lifeline’ alarm. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I have a Texecom Premier24 alarm with Com2400 connected to our PSTN line to send SMS messages after an alarm.
I have recently installed a Tunstall ‘Lifeline’ alarm which also uses the BT line, so I have ‘daisy-chained’ the two alarms with the Premier24 lines connected directly to the BT Master Socket and the R1/R2 lines feeding the Tunstall unit.
I now need to program the Premier24 so that it will NEVER answer any incoming call – the Tunstall unit needs to do that.
In UDL options, I thought I needed to set ‘CALL DEFEAT’ to ‘OFF’ BUT the manual’s wording suggests that if it is ‘ON’ an incoming call will be ‘defeated’ (i.e. Ignored).
I’m confused. Does ‘CALL DEFEAT’ need to be ‘ON’ or of ‘OFF’ to meet my needs, and are there any further changes required?
Many thanks.
Reply to Texecom Premier24 sharing a BT phone line with a Tunstall ‘Lifeline’ alarm. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
