- Reaction score
- 8,192
I would rewire it all in 4mm SWA , all metal tie wrapped to some nice Galv Tray strutted to the roof joists
Discuss Thatched wiring - ways to make safer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Why 4mm?I would rewire it all in 4mm SWA , all metal tie wrapped to some nice Galv Tray strutted to the roof joists
...cause I got a load of it in the shed that needs using upWhy 4mm?
Only has to be disconnected one end and a draw cord pulled through then the existing T&E can easily be terminated in a standard stuffing gland, not rocket science although some on here think it is.
I have thought this through, it is only lighting cables that are needing protection, these will be run from rose too rose so easily disconnected and pulled back and through a flexible conduit
no else seems eager to have a punt on a solution,
Reply to Thatched wiring - ways to make safer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
