- Reaction score
- 8,946
My first thought too, but when I re-read his post he's considered that and customer said no.Steel adaptable box with din rail terminals?
Discuss Through Crimp Tool in the Electrical Tools and Products area at ElectriciansForums.net
My opinion is that that hand ratchet tool you link to won't deliver nearly enough meat for 10mm crimps. More leverage needed IMHO.Yes as per the links in the first post. I just wanted to know if there were any recommendations other than the ones I intended to buy.
CEW sell a nice SWA brand of crimps for £30My opinion is that that hand ratchet tool you link to won't deliver nearly enough meat for 10mm crimps. More leverage needed IMHO.
With disclaimer that I don't own either of them, but at the budget end of the market I'd have thought that either this hydraulic set:
Vinteky Hydraulic Crimper Tool Kit Tube Terminals Lugs Battery Cable Wire Crimping Force Wire Tool 4-70mm 8T : Amazon.co.uk: DIY & Tools
Shop Vinteky Hydraulic Crimper Tool Kit Tube Terminals Lugs Battery Cable Wire Crimping Force Wire Tool 4-70mm 8T. Free delivery on eligible orders of £20 or more.www.amazon.co.uk
or this set with a lot more leverage:
Amazon.co.uk - https://www.amazon.co.uk/dp/B07L2S8FWR/ref=sspa_dk_detail_6
would serve you better. Of course others may have better suggestions. I tend to borrow a mates set and really should get a decent crimping tool!
It can be a bit tricky.. but wedging the crimp in the crimpers first helps alot, as does proper length of stripping. I also have a small vice that clamps to various things... so clamping the cable in there can also help.Does anyone else find that you need about three hands to use larger size crimpers? Small single handed 0.5-6mm ones are easy but as soon as you've got two lever arms it's a juggling act to keep the crimp and cable in place.
Yep - just not so useful for getting a lug onto a cable in a DB!It can be a bit tricky.. but wedging the crimp in the crimpers first helps alot, as does proper length of stripping. I also have a small vice that clamps to various things... so clamping the cable in there can also help.
That is why I like the SWA-brand lugs as the tube is slightly flared so when you slightly crimp it won't slide down while you make sure the cable is pushed in with your third hand.Does anyone else find that you need about three hands to use larger size crimpers? Small single handed 0.5-6mm ones are easy but as soon as you've got two lever arms it's a juggling act to keep the crimp and cable in place.
Reply to Through Crimp Tool in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
