Search the forum,
Discuss Track lighting Advise in the UK Electrical Forum area at ElectriciansForums.net
When a 20W LED spotlight of the same brand and design is added to a 5-meter single-wire track system, which already has four 30W LED spots connected to a Varilight 300W 2-Way LED Replacement Dimmer Module, the entire track system experiences dimming. Why does this happen?
Have you tried adding another 30w led
If that works ok presumably the issue is with the 20w . A fault or incompatibility issue
Hello, indeed, it's quite peculiar. I have tried using two different 20-watt spotlights, but both appear to cause the 30-watt lights to dim. I don't have a 30-watt for comparison.
Are these track lights mains or a lower voltage off a transformer, could be the transformer is not able to supply sufficient power.
Reply to Track lighting Advise in the UK Electrical Forum area at ElectriciansForums.net
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi all, after a bit of advise if ok please. We have a switch which currently only powers one single LED down light in our ceiling. From this...
I installed a 3-way Lutron dimmer toggle switch in my basement to control 5 dimmable LED track lights, LED track lights slowly brighten to near...
