Search the forum,
Discuss Two speed wiper motor in the Auto Electrician Forum area at ElectriciansForums.net
I have a 1960 Triumph TR3a which has one-speed wipers that just move the water around. I decided to put in two-speed wipers using the Lucas motor from an original Mini. The connections are power, low-speed, high-speed and park. My question is do I need to earth both low-speed and high- speed to run the motor on high, or only high-speed connection? I know it runs using the high-speed connection only but am not game to use both in case I let the smoke out.
Reply to Two speed wiper motor in the Auto Electrician Forum area at ElectriciansForums.net
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
For the past few years, I have used a hydronic system (outdoor wood boiler) with both high and low temp working simultaneously. The low temp...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Hi, I am trying to wire a two speed switch to a three phase motor. I have continuity checked the switch in both positions 1 - Low and 2 -High (See...
Has anyone taken apart their & self repaired it? 2013 Dodge Grand Caravan SXT - Mileage: 112223 - DTCs - P0480 cooling fan. Also codes in TIPM...
