Search the forum,
Discuss Unable to part set when leaving property, but can if staying home. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
SteveB112
My Veritas R8 Excel panel recently developed a power fault and I have replaced the entire unit and reprogrammed it. I can part set the alarm when going to bed and unset in the morning. When I wanted to go out and the exit door was open I could not part set the panel. The keypad did nothing and did not bleep. Is there a setting somewhere that I need to change or program. The control panel is in the hall, there is also a PIR in the hallway set to Inhibited Entry and then the final exit door.
I haven't seen this before.
Regards,
Steve...
Is the exit door set to final exit? Not sure about veritas as i haven't used them but on pyronix there is immediate set and timed set, may possibly need to be set to timed set to allow you to leave
Thank you for your reply I will look at the installation guide. I've programmed the same model twice before and it was OK. Maybe the newer firmware is different? Setup wise nothing has changed and all PIR's etc., are the same as before.
Regards,
Steve.
Reply to Unable to part set when leaving property, but can if staying home. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
My burglar alarm went off last night when it wasn't even set. When I went to Keypad it was showing TAMPER with a Red light. I could not silence it...
13K
Hello I’ve recently had to rewire my home alarm system as the engineer who installed it did such a shoddy job that all the cables were hardly in...
I have a problem. Not only am I not an electrician, but I need some help understanding what options are achievable so that I can go back to the...
A
Hi all, I've just replaced the keypad on a veritas r8 pre-2000 system as the old keypad had few worn buttons which weren't working correctly. The...
Specialist
T
Hi Everyone I hope you can help me on this issue. I installed the above panel in my partners house and it has been working fine for 8 months...
5K
