Search the forum,
Discuss Veritas R8 6 beeps unset in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all,
Requesting your help please! I know this is an old system but has been working amazingly for 7 years!
I had an engineer out who done a reset apparently however it hasn’t cured my fault!
When the system is not activated the main control box beeps every 30 minutes or so three times, twice. So a total of three beeps. The engineer admitted he’s not experienced with this alarm and is now unable to help.
The system allows me to set it however neighbours state the alarm goes off randomly through the day.
Any suggestions please? 🙏
Hi all,
Has the battery and supply been tested
Along with the bell box.
You could try disconnecting the mains supply and see how the system reacts, it would give an indication that the battery is good.
Hi bud,
Mains supply was tested and he had a voltmeter on the battery said it was fine at 13.1v
He didn’t have a look at the bell box? Is there a battery in that too?
Thank you for your fast reply!
Hi bud,
If you disconnect both mains and the battery, the alarm box should go off if it has its own internal battery (SAB) self activating bell)
The battery hasn't been tested under any sort of load you can do that by disconnecting the mains to see if everything holds up for about 20 mins.
I have just tried that and with the battery off and then the fuse pulled the bell outside done one really quick loud beep and that was it.
I shall kill the power on the main fuse board so it runs off the battery and sees what happens!
I looked everywhere for a code to tell me what the beeps meant but couldn’t find anything!
Thank you so much for your help!
As a guess I would be looking at the tamper switch in the bell box.They can rust and cause all sorts of problems.
If you don't want to replace the bell box then short the tamper switch out inside the bell box.It will no lnger have tamper protection but you can see if it cures your problem and then take it from there.
Reply to Veritas R8 6 beeps unset in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Apologies if this is the wrong forum thread. I have installed myself a Texecom veritas alarm system. it’s either the r8 plus or excel, as it has...
Hi, could somebody please give me some advice? I have a Texecom Veritas R8 alarm. I recently turned off the power for some DIY work, and the...
23K
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Hi there, could anyone please offer some advice on the following? We had a power cut on our street and when the leccy came back on our alarm went...
7K
Hi all, Just an old problem I wonder if anyone can advise me on. First of all I do not have the engineers code to my alarm, I have read...
7K
