Discuss Voltage optimizers any good? in the UK Electrical Forum area at ElectriciansForums.net
Thanks. I've since done a bit more reading. According to this report they save you about 6% a year. >> https://www.ofgem.gov.uk/sites/defa...-saving-trial-report-for-the-vphase-vx1_0.pdfThey work in so far as they reduce the voltage, they don't work in so far as they don't reduce energy consumption by any appreciable amount.
I have fitted one of these voltage optimiser/stabiliser units in a situation where the incoming supply voltage was sitting at 250V and the installed equipment was designed for 230V and was regularly failing due to the over-voltage.
I wouldn't bother there are too many variables to create an exact same useage profile over two 3 month periods, I would think even doing it under laboratory conditions would prove difficult to replicateIf you install one, please wait for 3 months, have some good evaluation of the consumption and then do an identical evaluation for 3 months afterwards and post the results here, it MIGHT be the first real life proof that they save energy!!
How was this measured though? I wouldn't trust simple meters as the sine wave is often distorted by harmonics and the rms calculation might be inaccurate because of it, I assumed if it was out of tolerance ukpn would sort it. Do you have solar and was the voltage causing an issue?I have one installed without it I had 258v come through the sockets and with it I get 220v, I've had it since 2015 I've had no problems with it at all.
That is a use-case where they make sense, although 258V is out of the ESQCR range of +10%/-6% on the nominal 230V (rule 27.3b) so it should be corrected anyway:I have one installed without it I had 258v come through the sockets and with it I get 220v, I've had it since 2015 I've had no problems with it at all.
I don't Have solar just a two bed terrace house in town built in the 1800sHow was this measured though? I wouldn't trust simple meters as the sine wave is often distorted by harmonics and the rms calculation might be inaccurate because of it, I assumed if it was out of tolerance ukpn would sort it. Do you have solar and was the voltage causing an issue?
Reply to Voltage optimizers any good? in the UK Electrical Forum area at ElectriciansForums.net
