Discuss Washing motor - bench test in the Electrical Appliances Forum area at ElectriciansForums.net
My beko will not run, it attempts to move in both directions with a belt or not fitted also shows no faults in checking with a meter across its tacho, stator or field as it will not run.
The brushes are a good length of 30/40mm when removed.
Need to bench test to prove if the motor is at fault or pcb board.
Got a 8 wire connector, earth, 2 x red for tacho, 2 for stator and 2 or 3 for the field.
In between the two field wires brn and org is a blk wire. Is this the thermal wire ?
If so, can i then bridge the stator and field wires to carry out a bench test.
Reply to Washing motor - bench test in the Electrical Appliances Forum area at ElectriciansForums.net
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
Hello all Just looking at a Samsung EcoBubble washing machine that's fairly new and been an issue for some time apparently. It's in the...
7K
Hi I don’t know how resolve this so any helpful advice would be greatly appreciated. I have no electrical knowledge. I will try to be as clear...
11K
L
I would like to know whether I can run a 1/2hp (~380W) washing machine motor on a 600W (1200W peak power) pure sine wave inverter...
