Discuss Water cylinder thermost question in the UK Electrical Forum area at ElectriciansForums.net
mhar
I have a customer who has an 18" thermostat in their water tank which periodically requires resetting. I went to replace this but am unable to put a new 18" one in as the tank is very close to the ceiling and the thermostat is withdrawn in an upward direction. I can get the 18" one out by bending (and probably breaking) it, I would be able to get a 7" one back in, maybe even an 11".
Obviously a 7" one would be reacting to the heat higher up than an 18" one, however I do not necessarily see this as a disadvantage. Am I missing something?
I have mailed a manufacturer to ask but not had any response from them
7" stat will switch off earlier than 18" up to temp.
Does the element have a plastic cap/lid ? metal ones dissipate the heat. Make sure no clothes are aired on/near the cap and it has space to breathe otherwise it will trip more frequently. If it is old then you do not have much choice....holesaw the ceiling so you can replace one via loft access if poss...future maintenance is important but often overlooked.
Reply to Water cylinder thermost question in the UK Electrical Forum area at ElectriciansForums.net
Hi, I've got both a solar pv and an ashp system. The solar system also has 2 batteries and it's configured to fill the batteries first and then...
HI Folks. This is my first post so apologies if it's in the wrong location. I recently installed a 3kw Solar system with an iboost diverter...
5K
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Dear community, as the Pro Nest are too fare away from my place in Italy, I am seeking here for advice. The actual work will be done then by my...
I have a customer, a butchers who have a hot water tank to run taps for washing hands and equipment etc. normal domestic cylinder with an...
