Currently reading:
Westinghouse wall oven cutting out.
Discuss Westinghouse wall oven cutting out. in the Australia area at ElectriciansForums.net
screwg
Hello All. I have a Westinghouse pxr6988 wall oven. It has a cutting out problem when using it in Keep Warm mode, it heats ok and stat is working. But, when I turn it off the oven goes dead, no clock etc.
The trip switch on the electrical board is not tripping. But to get the oven to work again I have to switch off the trip switch and then turn it back on. The oven works fine on high temps. The oven is hard wired. Looking forward to some clues.
Thank you,Chris.
Reply to Westinghouse wall oven cutting out. in the Australia area at ElectriciansForums.net
